Blackout Lights wiring
cucvegas
12
NW Arkansas
Could someone tell me if it matters which wires are connected on the rear black-out lights?
There is a two-wire harness on the vehicle (green and black), and there are two wires on the black-out light. One of the wires on the blackout light has metal clips with the part number. Does it matter which wire connects or does it just complete a circuit either way?
Also, is the third wire (not in a harness) the ground that screws to the threaded post on the back of the light?
Thanks!
cucvrus
10,316
Jonestown Pennsylvania
The lights you have with the black wires and metal tags are not original GM lights. They will work. The back ones have 3 red LED slits as park lamps and you must also note in the center is a single yellow slit that is a B/O stop/ Brake light. The 3 wires to each rear corner will be a semi ridged black wire for a ground on each lamp. Ground to the mounting stud with a star washer. Then you must probe and discover which wire is the B/O park and which is the B/O brake / stop wire. Wire them accordingly. The front lamps will have 2 wires and 2 yellow LED slits will illuminate and you have a semi ridged black ground to the mounting stud and a park light wire to the center single wire on the back of the lamp. I hope that helps. Good Luck and Be Safe. The original GM B/O lamps were discontinued early on. I know by 1995 the were out of stock at the dealer.
cucvegas
12
NW Arkansas
Thanks. Got it wired up. Front work great.
do the rear lights change from single yellow to four red lights? Hitting the brake did not light up the red lights. Should only the yellow be lit when you turn on the blackout lights?
If I switch the wires, the red would light up instead.
Since I didn’t have the wire harnesses, I just wired them with connectors to be able to swap them if needed.
thanks again!
cucvrus
10,316
The 4 red LED slits should light on B/O. The yellow single slit should also light when the brakes are applied and the switch is in B/O position. You may have the wires reversed. Check back and report. Good Luck. Be Safe.
cucvegas
12
NW Arkansas
Switched the wires. Now the rear four red LED’s turn on when you turn on the black out switch. However, the yellow middle one does not turn on when you press the brake pedal.
It seems like the single yellow marker should come in when you turn on the switch, and the red should come on when you hit the brakes. But when it was wired the other way, the yellow would come on with the B/O switch, and nothing happened when you hit the brakes.
I‘m actually thrilled to have anything light up when I flip the B/O light switches.
