Bobbed Deuce Wight Distribution Question
GPappy
Michigan
Bobbed Deuce Weight Distribution Question
I did a search but could not find the answer to this question so forgive me if it is buried someplace, I couldn't find it.
Has anyone weighed their Bobber and know what the weight distribution on the front vs. the rear is on their truck? I am working on suspension design and want to figure the weight on the rear. I realize that it will vary by bed type and wheel base but I need to start someplace.
Would also like to know if anyone has the weight of the rear axles?
GPappy
Michigan
Mine is- W/W and M105 box
Front axle: 7080#
Rear axle: 4700#
I had assumed 60/40 so not too far off. So if you assume 2 ton load capaility the GVW would be just shy of 16000# and the weight using the front springs on the back would be just about right.
I got a good deal on a set of new airsprings that are rated for 8000# so they are going to be way over kill given deducting the unsprung weight in the back and the load must be more like 1700# per side and less than #3500 fully loaded. Now I need to find out how bad it would be to run the air springs so much below their optimum loading or stick with the trailer springs.
Thanks for the information.
