Ma Duce
- 22
- 18
- yorkville, IL
So as Mark and I were prepping for tommorow recovery, we were talking about the bobber projects we are going to undertake.
He said he had some springs off of a truck he was goign to part out and I could have them. I looked at them and then looked at the springs on the front of one of his A3s and noticed the A3 springs looked a bit beefyer.
So I counted and I counted 12 leafs inthe A3 and only 8 or 9 in his old parted out multifuel. We then went over and looked at the springs on one of his trailers and it had the same number as the A3 fronts, without counting the helper springs.
So the question comes down to, can you use earlier front springs on a A3 bobber or do you need to use A3 front springs if you are not going to use the trailer springs?
And does anyone have the specs on the A3 fronts, to have a set made? I would like to get a quote from the local spring shop just to see what they would cost.
