jdfritzsch
- 0
- 0
- NNJ
New at this, sorry if this isn't posted in the right place. Started the bobbing project on my 931. Putting a 105 bed on it. Just wondering what you guys are doing for drive shafts? Thanks
Dont believe that is possible when using a 105 bed due to the wheel well unless you cut the box.Do it like hawaii5ton just did and use the old drive shaft. http://www.steelsoldiers.com/showthread.php?109971-M923-Bob&highlight=hawaii
any "heavy" truck parts house will have them.. just take one of your front lug nuts in to match them up.. and remember that one side is right hand thread studs, and the other is left hand threads... the nuts that are on the front axle, is correct for the super single rims...Bobbing the 931, want to put super singles on; Does anyone know where to get lug nuts for super singles?View attachment 441717
Hacksaw takes care of the axle pin problem.Rear axel not alined, on one side by a couple of inches, has anyone else run into this problem? The hanger brackets were hung first. Seems like axel pin is in different spot on other side.
