edgephoto
- 1
- 18
- Stafford, CT
A friend and I bought 2 MEP-002a units from a GL auction recently. We had worked the other night for a few hours inspecting and PMing the units. We started to clean the fuel system, replaced the oil filters and filled the crankcases with oil. Today we worked on finishing the fuel system cleaning and we cleaned the fuel pump screens. Old diesel smell as bad as old petrol.
We removed the glow plugs and did compression checks. Both engines had about 350-375 psi. Getting the glow plugs out took some work. We worked them back and forth many times. We did not want to break them off in the head. Once out we cleaned the terminals and ran a die over the threads to remove the carbon. The were all good and measured just under 5 ohms each. We chased the threads in the head and put them back in.
We finished cleaning out the fuel tanks. They do have some internal rust but we used nuts and bolts to try and get most of it out. We then used acetone, followed by gasoline and then fresh diesel to rinse out the tanks. Put Marvel Mystery Oil in the secondary filter and then ran the pumps until they stopped pumping fast and the return was going to the tank. Eventually we will coat our tanks but for now they should be good. If any rust is in the fuel I think the filters will do their job. There is enough of them.
We got lucky as one unit came with 2 batteries that are good. One unit is missing a couple hoses. The other unit is missing the fuel check valve assembly.
Once we got the fuel systems back together we attempted to fire them up. The first unit would not run the fuel pumps. Only the Aux pump ran. No voltage to the pumps. Traced it back to loose screws at the terminal board inside the control unit. Almost all the screws were loose on the terminal board. Now we have one of the 2 pumps running. The other gets voltage buts does not work. We will deal with that later. At first we had a fuel leak but that was quickly resolved. Then we attempted to fire it up. She fire ran for a short time and died when the start position was released. Several more attempts were not as successful. We then moved to the other unit. Since that unit is missing some fuel system fittings and hoses we swapped them over. That unit fired right up and stayed running but the frequency and voltage gauges were not working so we shut it down.
We called it a day. The one that would not restart we will put the fuel check valve inline and then see if we have fuel at the injectors. The other unit we will do some electrical checks of the gen head.
