Brake light switch ?
Vfflang
Mascotte/FL
Gentlemen
Where can i find the brake light switch for the rear brakes ..
I have running lights in the rear but no brake lights
Can i buy the switch from NAPA if so does anyone know the part number
emmado22
147
Mid Hudson Valley NY
Vfflang
Mascotte/FL
Ok found the switch it the upgrade seem not to be working ...how do i get it off seem to be in a tight space any ideas ? Thanks
73m819
319
gainesville, ga.
Bypass the switch wires, the brake lights should stay on, if they do , the switch is bad, if the lights do not come on then it is WIREING, be sure your LIGHT dash switch is set in the CORRECT position
Vfflang
Mascotte/FL
Lights work now how do i get the switch off its seem to be a tight space do i need to drop one side or the whole thing to get it off
Vfflang
Mascotte/FL
Thank you to everyone. I was able to fix the brake switch today I removed the bad one today and replace it with a new one. I was able to picked one up from Autozone. I rigged a universal switch with a brushing and the rest is history its about $8-9 dollars to make, here a photo.
Jakob
Louisville, KY
Jakob,
Please read the warning DogHead posted just before yours. You can try Brake Light Air Operated Switch Upgrade Kit For M35A2, 12255668 . I see that they are out of stock, but you can look around and get one from the other supply houses.
4x
That isn't what I was talking about, I've already caught the warning as well, thank you though.
What I was asking about was using a Chevy brake light switch on the brake pedal instead of the Deuce switch on the air pack.
dw9339
Texas
I called several places and found two who had the entire kit in stock. One was $85 and one $55. Here is the link for the cheaper kit:
UCOM #7006 Stoplight Switch Kit
If you want to order from UCOMINC, you need to call them directly, and note they open and close early, I believe 5-2:30 EDT.
The only issue is that the kit I received does not have the instructions I've seen referenced on the site that sometimes come with the replacement kit.
Does anyone know what TM has the work instructions to install the replacement kit? Maybe it was posted earlier, but I have not found it to date.
