Brake pedal/switch question
cdohner44mag
67
12
Camden, DE
So my question mainly is, how much travel should there be with the break pedal. Mine has almost no travel, breaks work very well, but I only have to push down maybe a 1/4". It's not enough travel to activate the break light switch, at least it seem. I've made all the adjustments I can to the switch, just feel like there should be more than 1/4" of travel and was wandering if I have an issue going on. Thanks.
Mogman
8,855
Papalote, TX
This seems to be a common "issue" not really a problem, someone should crank up their CNC machine and knock out some 1/4" spacers for the master cylinder as I don't think there is any adjustment available, may even be some spacers out there in the hot rod world, I have never looked.
EDIT, I did look and there are some out there, nothing right off hand that looks like it is for the GM master cylinder, but many are 3D printed, makes sense as they are not really under allot of strain.
cdohner44mag
67
12
Camden, DE
I tried bending the rod and bracket and it helped some. Now the lights come on when at a stop without having to stand on the pedal but still not enough when light pressure when slowing to a stop. I will look into spacers to see if the will give me the extra travel I need. Thanks for the ideas guys.
Mainsail
1,521
Puget Sound, WA
The word you're looking for is brake, not break. It will matter more in the future when someone is doing a keyword search on the site for the same problem you describe. ;)
cdohner44mag
67
12
Camden, DE
You are correct. Darn auto spell and I didn't notice it, thanks for catching that.
86humv
493
Texas
After awile, those switches get a bad spot inside....sometimes adjusting helps it inside on contacts.
Coug
4,227
Olympia/WA
it's also recommended that you use LED bulbs in the brake light position if you don't have the newer LED assemblies for the rear, to reduce the amount of current going through the brake switch which in turn reduces wear/arcing
Coonass77
179
33
North Carolina
Try adding washers between the switch and mounting bracket. I've had to do this on a few trucks and have more luck with washers than bending the rod.
