Broken AC drain line
504GNG
New Orleans, La.
Recently purchased a first HMMWV M1161A1 and the condensate drain line from the AC over the passengers leg area is broken. The piece in the hose is a standard barbed nipple/ male piece, but I am not sure what the other side's connection is supposed to be. Did that side break off of the housing of the unit or is there another male piece stuck inside of the housing?
HoveringHMMWV
1,037
AL
To me, it looks as if the male piece has broken off of the condensation drain pan case. May be able to remove the pan for repair with an epoxy or simply replace the pan. Removal may be challenging in that confined space where you can't see the mount points.
Milcommoguy
2,187
Rosamond, CA
NO expert on this BUT.... looks to me you have enough material to tap some threads in it (plastic or metal ?) then screw one of these in there.
May have to take some threads off if threading it all the way in... to get it flush to the inside for proper draining. JB weld the , heck out of it.
Tap, glue, screw and hammer, CAMO
