I'm not sure, but from what I found with that compressor, it uses a 50 amp breaker. Did you have anything else hooked up to the genset with the compressor? Curious as the startup amps might be around 40 so it could be the motor didn't get enough to actually get going while under load from the compressor. I think if so, then I'd start the electric motor with a bypass on the compressor pressure side so there's very little load on the motor, then slowly close it to ease ramp-up amps.
Sent from my SM-S906U using Tapatalk
Had a couple of small mini splits on and some lamps. I was in the garage and cannot say but "maybe" the well kicked on too..... Great idea about the gradual loading and startup load checks, and I do intend to have wiring checked at the receptacle prior to startup.
The opinions of folks will vary as much as Google's AI will when trying to give you an answer to the same question. Bottom line, thankfully nobody was hurt. It could have been anything from a reversed Neutral to a loose connection. Even with pictures it will be difficult to discern the root cause. If you want a definitive diagnosis, my best thought would be to bring in a licensed Electrician to examine the carnage and install the new compressor motor. While he's there, he can examine your generator connections and interlock devices to ensure they meet code so you aren't confronted with this dellima again.
Edit: along with the notes mentioned above, the Electrician can also measure the startup power draw of your compressor to further help with that hypothesis.
Sent from my SM-G970U using Tapatalk
[/QUOTE]
Y
Affirmative on 50A breaker. Motor 1274661009 is discontinues I think, but will do some more archive research to check if there is a data sheet available other than data plate on motor. Had a couple of small mini splits on, fridge, freezer and some lamps. I was in the garage and cannot say but "maybe" the water well kicked on too..... Great idea about the gradual loading and startup load checks, and I do intend to have wiring checked at the receptacle prior to startup, and will consult with electrician on advisability of trying to run the compressor on the genset .
