Cadillac valve
Mogman
9,304
Papalote, TX
Looks like it is blocked, your fan should be running 24/7, maybe a mongo leak between the fan shroud and the clutch?
Salty dog
175
Spring, Texas
I appreciate all the help, I have been trying to go through the TM for a reference to see how the hose is routed. I took a look under the fan shroud and do not see anything connected to the fan clutch. I did see this attachment point on the back of the radiator but unsure its purpose
Mogman
9,304
Papalote, TX
That is where the hose goes.
The hose that goes from the other side of the fitting to the fan clutch may be missing, that could be why it was plugged, that hose is a PITA to replace.
OR the hose may just be laying in the bottom of the fan shroud not connected.
Mogman
9,304
Papalote, TX
I am going to go out on a limb here and say that possibly the quick connector was leaking and someone thought unplugging it would stop the leak, when it did not they pulled and plugged the hose.
If you find the hose just laying there it might be a good idea to order one of the female connectors, seems they all leak sooner or later.
Mogman
9,304
Papalote, TX
I was wrong, the nut is on the inside(#20), I thought it was on the outside, getting old o_O
Maybe someone has done it but it looks next to impossible without removing the radiator.
If that fitting had the nut on the outside it would be possible to fish it to the hole and put the nut on it..
