Camo Cover Pattern
Tinwoodsman
76
Comfort, Texas
Are the patterns on all of the vinyl camo cargo covers the same. For example, if you paint the truck to match the cargo cover, will it be the same if you replace the cover? I am sure the government has more that one source but do they follow the same specs?
emmado22
147
Mid Hudson Valley NY
Yes, they all follow the same spec. One M35A2 cover's camo pattern will match another company's M35A2 cover's camo pattern. The variation may be like 1 inch plus or minus, but thats OK as it is within the spec.
Just make sure you have the cover on the right way when you paint the truck. (not back on the front or vice versa)
Stonepicker1
86
Coconut Creek, Florida
:ditto:but, there are some trucks out there that were painted camo " not by the book". so the pattern will be off.
Tinwoodsman
76
Comfort, Texas
Hmm! That complicates matters. I have a cover that needs to be cut down to fit my bobber so I will have that done and then do the camo pattern on the bed. Thanks all.
