SSGTUSMC
- 2
- 3
- Hubert Nc.
Can you run JP8 in the CUCV M1009? I half a tank of diesel in now and want to know if I can put JP 8 in . thanks.
Sent from my SM-N960U using Tapatalk
Awesome thank you!JP8 an inferior fuel?!
........Hardly
JP8 is an excellent fuel and has several additives that aren’t available in the civilian world.
Run it all day long without worry.
It meets or exceeds gel point, corrosion and particulate. But it doesn't meet wear scar or cetane index as these are CI specifications for diesel. Yes, it CAN be used but it isn't a DIRECT replacement. Therefore it is an inferior replacement good. It has slightly lower energy density too.JP8 an inferior fuel?!
........Hardly
You can do that with almost zero issues.......Add PRIST if its too cold outside!
Hahahh...Yeah but it sounds cool to tell folks your truck runs on jet fuel. ��
