Lust4GreenSteel
- 8
- 0
- KC MO
HELP Can't remove Master cylinder m35a2
The TM says that after you remove everything, you should back the MC into the frame and remove. End of task.
It doesn't seem to be that easy. I removed the 11/16 fitting on the back of the MC to get it to clear the frame opening, but now the back of the MC is hanging up on a solid line (frame brake line?) just above it.
Am I missing a secret of some kind. Is this like those magic puzzles where you have to twist the links in the exact orientation to each other or it won't come apart?
My truck lives at a farm 90 miles from where I live, so I have limited time to work on her. I am at the farm today, but may not be able to return for several weeks. I would really like to get this MC replaced this trip, so any suggestions or advice will be much appreciated.
Thanks.
Thanks.
