can't restart after changing fuel filters on my M923A2
Jbulach
2,136
Sunman Indiana
Make sure the batteries are still spinning the motor quickly, zip tie the fuel shutoff back temporarily, and put the throttle to the floor while cranking. It should then light, especially if you were already getting fuel at the injectors.
Doug Roberts
Chapel Hill, NC
thanks so much. I did get it started this morning. I cracked the fuel housing and filled it up over the edge and sealed it shut , primed it again and it cranked right up.
71DeuceAK
407
Fairbanks, Alaska
Have you tried pressurizing your fuel tank yet? I've seen everything from putting a Schrader valve/air chuck in a spare fuel cap to pressurizing with an air wand filling the hole with a ratchet strap rolled up to a leaf blower.
