Canvas for the xm757
cranetruck
75
Meadows of Dan, Virginia
Since the original vinyl top is almost impossible to find, I'll have a canvas "bikini style" top until I find one. Started working on it a few days ago....
There will be a second piece covering the equipment behind the seats.
BKubu
1,164
Gaithersburg, MD
Bjorn: I doubt you'll find one surplus, although you'd think there would be one out there some where. If you can give them the old remains and measurements, a place like Beachwood Canvas can replicate your old top. Same goes for WeeBee Webbing and New Life Canvas Resources.
cranetruck
75
Thanks Bruce for the suggestion, there are some floating around, I missed one at Joe Naglich by about a year and they are apparently still good made of vinyl and all.
Meanwhile, I'll make my canvas substitute look good. :)
cranetruck
75
A little rain, some sun and there is movement....maybe there was more than one reason for using vinyl to begin with, the 100 inch wide cotton canvas will shrink a lot.
I'm now considering using the vinyl(?) shown to the left in the image, part of a HMMWV top from Wayne Harris a couple of years ago (actually used it for padding when I transported a CUCV camper shell to Kenny at that time).
I also have second hand info that Sam Winer may have the real thing, so we'll see how it plays out.
cranetruck
75
Worked on the cab top again, adding reinforcement strips and eyelets...
The Goop silicone adhesive is incredible strong, spent a couple of hours with an Exacto knife separating about 18 inches of a glued, folded edge to be re-glued to allow for shrinkage.
The Goop is a little hard to work with since it doesn't flow easily, which may be seen in one of the images.
cranetruck
75
Well, got the top finished and went ahead and painted it in a Gillespie Field Drab color (not neccessarily the final color).
I plan to make the top portion white like I did the top for the deuce, which helps keep the cab cool. The white is not very noticable from the ground (see avatar).
1,179
Bjorn, Did you sew any of this top?(is it all done with glue and grommets)? Is this the same basic way that you made your "bikini" top on your deuce? How long has that one lasted and how is it holding up? It looks good!
cranetruck
75
Right, only glue (Goop) and the grommets. The deuce top is still like new, but then, I do keep it covered at all times unless the truck is driven.
1,179
Did you use brass "twist lock" grommets on the sides(over the doors) and if you did, where did you get them and the tools to install them? The new top looks good, nice work!
m376x6
Colorado
I had two M656's and bought two or three tops years ago from Naglich's. I sold one at an auction for 5600 and wanted to keep the second one. Looked for the better part of a year trying to find tires. Ended up selling it to someone back east. About a month later a fellow called saying he had heard I was looking for tires and stated he had around 40 of the 16-20 tubeless tires new sitting in his yard. My luck.
I have a pic of me driving it in the Petersen's 4 wheel and Off road magazine at a Power Wagon Rally that use to be held in Sedalia at Fred LaPerriers (sp?) place.
I believe the place was called Sweeds or something roughly similar out in Tooele. Red Tomlin may know who I'm talking about if they're still there. They were just north of his place. They had parts and pieces for these 8x8's. Maybe worth a call.
Regards,
M376X6
rmgill
14
Decatur, Ga
Bjorn, have you thought about adding and additional set of tubing to give the back of the cab more cover so you'd have more usable storage space you can reach from inside the cab?
