Change the passenger frame rail
Frost0071
Indianapolis/Indiana
Hello, I would like to change the passenger frame rail on my
1987 M1038 because I found some repairs on in and it just don’t look that nice anymore.
Can this rail be replaced with anyone out there? Does the
12K rails fit? Or do they have the mounting points on a different position? What
is with this rail PN/12469404-1 will that fit?
Thank you
Retiredwarhorses
4,181
Brentwood, Calif
Thank you
there are several flavors of frame rails, 7700 GVW, 10.3k, 12k, W/O Sheppard steering gear, W/newer steering gear.
stick with a 7700 GVW rail. But to answer your question, all the holes are in the same spots, I just wouldn’t mix and match GVW rails.
aghumvee
192
Blairstown,Missouri
I have new M998 humvee frame rails located south of Kansas City,MO. I think I have passenger sides but have to double check part number.
Let me know if interested.
Andrew
aghumvee
192
Blairstown,Missouri
The frames I have are:
Right Side
NSN 2510-01-440-5301
Part Number: 12469404
They are new in the crate painted black carc. Weight is 310 pds.
$150 each
Thank you,
Andrew
