stranger75
- 0
- 6
- Nashville, TN
PHASE ONE:
A while back I pulled a headliner and interior trim pieces from an 83 K5 Blazer. Today, with the much appreciated help of StationJJ, I installed this interior in my M1009.
The interior trim consists 5 plastic pieces and 3 metal ones. I cleaned them up and spray painted them with Rustoleum Camo paint from wallyworld. The can says it bonds to plastic. So far it seems to be working. The trim can easily be cleaned of dirty fingerprints and smudges, and if I scratch them I can always touch it up with more rattle can.
I picked up a couple of ALICE ammo pouches, and MOLLE adaptors. To mount these onto the trim I used a dremel tool and a drill. I cut out notches for the MOLLE straps to fit through, and holes for the snap buttons. It only took about half an hour and was an easy mess to clean up. I like the way the pouches look, hanging above and to the side of the driver's head and passenger's head. I haven't filled them with anything yet, but I plan to.
I covered the roof with Peel N Seal before attaching the trim/ headliner. This is part of my plan to dampen engine/ road noise, and hopefully will assist in climate control insulation.
I also installed a unique dome light (currently working on wiring issue.). This light came in the ex-sheriff's office parts truck that I had (pic is of light still installed in parts truck). It is made by a company called Glar-Ban. I have not been able to find another one like it (google search), but I have found other Glar-Ban products. They made lighting and light filtering equipment for aircraft, and used to make products for military use. I'm not sure if the light is from the military or the sheriff's department, but it is OD green.
The headliner from the civvy K5 is basically a piece of cardboard. It was actually the most expensive part of the original trim that I pulled, at about $11.00. I couldn't justify spending $249 on the plastic headliner from LMC, so I figured I would fix this one up. I was able to find automotive headliner material at Jo-Ann Fabric for about $15 a yard. It's the most manly roll of fabric in that store. I stripped the cardboard of rotted liner material and foam, used 3M Spray 77 and attached the new material. Installing it with the trim was kind of a headache, but we got it done.
The trim and headliner hide the wire for the dome light.
Here are some pics, more when the sun comes out again.
