Coil test
Kcdan4th
Nashville Ga
Does anyone know what the resistance on a 24 volt coil should be. I have 12.7 ohms on the primary circuit and 17.85 on the secondary. Problem is no fire at the points. Thanks
Bill W
45
Brooks,Ga
if I remember correctly you don't want a coil that reads Below 9ohms otherwise you could start frying the points ( to hot of spark )
