Cold Weather Starting
oldshep
Clever,MO
Is there any thing I can do to help my ldt-465 start better(as is quicker and smoother) in sub freezing temps. It starts good at 40 degrees. Will it hurt to give it some gas while cranking? Will letting the tank pump run a little before starting help. I dont have any engine heaters on it. Thanks for your commments!
jwaller
19
Columbia, SC
keep the batteries stored in doors and installed them in the truck when needed. it will make a huge idfferance in the battery life and starting ability.
cranetruck
75
Meadows of Dan, Virginia
Re: RE: Cold Weather Starting
A battery warming pad works well too, but needs 120VAC.
The intake manifold heater (flame heater) may have some issues and can't be relied on especially if your engine is turbo equipped IMHO.
If you resort to starting fluid, use it sparingly in small puffs and only while cranking.
Make sure you don't have air in the fuel lines and bleed the lines (valve on top of secondary/final filter bracket).
doghead
4 Star General /Moderator
1,175
NY
RE: Re: RE: Cold Weather Starting
Have you read the operators manuals?(should be reading the TMs in bed at night... :lol: ) Does your truck have the manifold heater or the either start? Does it(whichever you have) work properly?
Armada
Buick City, MI
I always open the throttle on mine when starting cold, it definately helps. I also use the ether injection for cold starts, one shot will bring the engine to life. Saves tremendously on crank time, starter wear and battery life. It's a very simple kit to install. If you do a search here, you will find that it has been talked about in the past. I think there is even a link for the kits. Good luck.
joec
Vincentown,NJ
add some diesel conditioner to it also all kinds out there. But what mudlord says works.I started mine the other morning at 30 degrees f and no problem
cbvet
20
Northwest (Knox) Indiana
My non-turbo Deuce rarely turns 2 full revolutions before starting. Have tried it down to 0°.
I don't know why it starts so well, or why it gets only 5-7 MPG.
Eric
CBVET
chuck500cc
DFW Area
Ok, I have been looking at these trucks for awhile but never asked. What is the orange canister on the firewall? :oops:
houdel
9
36
Chase, MI
Most Deuces are equipped with either a flame heater or an ether system for cold weather starting. The flame heater burns a small amount of fuel in the intake manifold while cranking to raise the inlet air temperature and make the main fuel charge ignite more readily. The ether system sprays a measured shot of ether into the intake manifold as a start aid. Either system if working properly should get you started down to 0F or better. The flame heater as mentioned had its share of problems so the ether start became the preferred system, with many trucks having the flame heater replaced by the ether system at depot rebuild. If your existing cold start system is not working properly, a 2-3 second shot of ether into the air intake mushroom should do the trick. As mentioned, DO NOT attempt to use ether and the flame heater together. Ether will NOT mix well with the burning fuel in your intake manifold!!!!
majortom
21
Aniwa, Wisconsin
My Personal Deuce has the ether injector, once you energize it the ether will discharge when the engine starts cranking, that truck will start at 25 degrees or higher without ether the lower the temp the further i depress the pedal my 543 has a non-lighting manifold heater it will start at 25 degrees by using the heater as a fuel enrichment device. i trigger it for two seconds and then crank the engine when it really gets cold that doesn't work. At ten below I use a healthy shot of ether sprayed after the air cleaner directly into the intake, i then depress the throttle halfway and with a little luck the truck fires right up. the coldest i have ever managed to get one of these trucks to start was at 28 degrees below zero. The big problem was not getting the engine to ignite but the fear of blowing a head gasket or other damage. Anytime you start one of these engines at freezing or below i strongly advise that you keep the engine running at the lowest possible RPMs for several minutes so all the parts are happy. Regardless which starting system you have if it is in proper working order and you have a solid motor and fuel injection system your truck sould start at 20 degrees without battery warmers, block heaters, or other devices
