Converted Gasser Guage Panel
randyman
Keyser, WV
Hello all. I was wondering if anyone had or knows where to find a guage panel for a gasser converted to multi-fuel that I could buy or trade for (I have some extra Solargizers and slave/jumper cable end connectors). The converted gaser guage panel is smaller than a regular multi-fuel and has a different layout (I think a small guage in between the speedo and tach). I think they also used a holder for the tach that mounted tto the bottom of the dash if the panel wasn't replaced. Thanks iin advance for the help and all the great info I've gotten from this site.
lavarok
33
Fellsmere, FL
BUMP - anyone else out there with these? I want to know if there are any around collecting dust just waiting for a truck before I spend some coin having a couple machined.
If not, then I have a guy lined up to make me a few out of aluminum next week. The more I have made the cheaper they are, so if anyone else out there is interested - PM me!
Thanks.
1,810
Ian, if you get no takers then don't worry about getting them cut if you need just one, keep the one I sent. I doubt that I'll ever need it.
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
I'm kind of confused, The early gassers had the speedo and after modification had the tach mounted under the dash-usually. I THINK the one in Lavarok's is a milti panel (larger one). A pic of the one you need would help (at least me) alot.[thumbzup]
1,810
Jim, I sent him an NOS one like the one he posted a pic of. It fits in the smaller hole of the gasser dash but has enough holes for the tach. Some came with this panel and others had the tach below like you pointed out. I wished I had that panel when I repowered the 108, would have loved to keep the factory dash.
nhdiesel
Milan, NH
So the dash gauge panel size is actually different between the converted trucks, and the multifuels? I have an early 60's that was later converted to multifuel, and it just has the speedo in the dash, tach is mounted below the dash. I would love to swap to the newer style panel, but it sounds like its not that simple.
Jim
1,810
Correct, the opening for the instrument cluster is smaller on the gassers. You can either find a panel like I sent to Ian, or replace the entire dash (not hard) with one that has the bigger opening. If you go that route, there is a support that goes from the dash to the firewall on both sides of the dash. You will have to mod or swap the one on the drivers side.
hndrsonj
363
Cheyenne, WY
Kenny, I was thinking the odd gasser panel didn't have the small gauge in-between the speedo and tach and just had the 4 gauges below them. oops...
lavarok
33
Fellsmere, FL
If I get them machined, they will be made from aircraft grade aluminum and anodized. The price will depend on the total number cut, so if your interested send me a PM.
