Converting 2 pin slave to 1 pin
khamill2000
kansas
Is there a way to remove the battery cables from a 2 pin slave port? Also, What gauge cable am I working with? Appears to be at least 2-0.
4,744
Depends on the style port. I know some ports have terminals with lugs on them that are simply bolted on. Others have a pig tail section of harness on them.
4,744
If you want to reuse the cables, you'll have to cut them off at the slave port and add lugs then.
