converting trailer lights?
wsmith350
Newark, Delaware
I know converting the trailer lights has been well covered in other posts, but I want to utilize the black out light circuits and bulb placement to gain dedicated lights. In other words have the lower B.O. light with an amber bulb for turn signals, the upper B.O. light for tail light, The main bulb for brake lights and the upper for a second tail light. has anyone combined the 2 circuits to achieve something similar? I hate to see the unused lighting options. Thanks for any help.
steelandcanvas
85
Southwestern Idaho
It might not be legal to do for a trailer placed upon the highway. I would not think enough light would pass through those tiny red black out lenes to be seen by the driver behind you. Just my 2 cents.
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
As mentioned above, even if you opened up the rest of the blacked out area it would be way small.
wsmith350
Newark, Delaware
I was kinda thinking the same thing, but wanted a little confirmation. Thanks. My plan B was to use the existing blackout light wiring for some auxiliary LED work lights.
wsmith350
Newark, Delaware
I examined the wiring for the BO lights, and its identical to the rest of the lighting. I installed a standard 7 way trailer connector. There's a port on the new connector for auxiliary power. I'll tie into that, and run a power port from the BO light pig tail in the back. I should be ok with a 12v LED light. They don't pull much power.
