CTIS flashing lights
JOR
kingston ny
Does anybody know why all the lights flash on CTIS at high speeds only. If I stay under 50 mph no problem. If I start going 60 mph down a main road it won't stop when I slow down the lights stop blinking. I'm thinking the CTIS just is over loaded. Any ideas?
MtnSnow
14
NSL, UT
It's blinking all the lights on the ECU because there is a failure of the system to achieve hwy pressure. If your talking about the dash Overspeed light it will come on when you are going over 50mph with out the tires being at hwy pressure
Coffey1
497
Gray Court SC
Both of my truck flash over speed over 55 even with the hwy mode satisfied.
Have you tried pushing run flat while its doing it's thing.
If it sees a low tire it will fault.
Mine after a week sitting I have to hit run flat to get a low tire up before it will go into hwy and stay there
JOR
kingston ny
Thanks. Ive checked all over. I feel better hearing mines not he only one doing this. Mine are aways fine unless I'm over speed and then its just the blinking lights when I slow down it stops.
