CamoCUCV
- 0
- 0
- Lakeland/Florida
Previous owner said it would start and idle but when you give it gas it would die. He was suspect of the tank having dirt or trash in it and when he pulled the tank he found lots of sand and uncovered pin holes. He had health issues and never resumed work on the truck. It set for about a year. Now its mine, Ive been reading post for weeks and trying everything I can. So I have a new tank and sending unit, I'm using an electric pump and a diesel screw on fuel filter. Previous owner has changed out glow plug relay to push button and solenoid. Ive ohmed glow plugs they are all 1.4 to 1.6. I'm getting 26VDC to all the glow plugs when I have someone push button. Ive tried holding glow plug button for two minutes and three minutes before cranking. I put two new 1000 CCA batteries with good clean connections. I cracked all the injectors and cranked it four times for about 10 seconds at least until they all drip, then closed them back. I'm hearing the click on the IP when I pull the wire off. Ive checked the check valve on top of the IP for the return. I feel like its cranking a little slow I'm afraid that its sat too long and its rusted up? It had oil in it when I got it and it was full but I've changed it anyway. I wanted to pull the glow plugs and turn it over to see if I'm getting a fuel mist out of each cylinder but every freaking glow plug is swollen and wont come out; they screw out but wont come out. But they ohm good? So should I go through all the trouble to pull and replace 8 swollen plugs just to see if I'm getting proper fuel? is there another way? Also is there a good way to free up a engine that may be a little tight from sitting? Also Ive made sure there are no restrictions in the return line by blowing into the line off the top of the IP. I'm concerned IP issue? or just not cranking fast enough or clogged injectors? I've tried a little either while cranking but no success. Need direction some help.
