CUCV Washer motor won't turn off
johnpdo
Buckner, MO
OK, my first post... CUCV wipers only worked on low, with no high and no washer working. Read the other posts,and disconnected the capacitors, wiring straight into the wiper motor. Cleaned the contacts, and now the wipers work on low and high, BUT...the WASHER motor won't turn off. Unplugged all the wires, and the wiper motor works, but the washer still doesn't stop. It appears mechanically driven. I see where some are using a universal washer motor. Is there anyway to fix my problem, or do I just need to breakdown and put in a different motor for the washer. If I do that, exactly which wires do I need to use to wire to the washer so the switch on the turn signal works. Any help?:cry:
Lieutenant
57
Michigan
I had one that the washer would not turn off, I replaced it with a later model washer jug with internal pump from a salvage yard.
johnpdo
Buckner, MO
I really don't get it. Even If I unplug the 2 wire and 3 wire connector, it still keeps pumping until the reservoir runs dry. Hmmm. Bought an Anco 65-01, and will probably just bypass it now.
cliffyp
Brownsville, Texas
I'm digging up an old thread to see if any of you resolved this.
I figured I'd fill my reservoir so I could clean my windshield, turns out if I run my wipers it will keep cleaning and cleaning and .... It always wants to leave one last squirt after the wipers stop. It's like my kid trying to get in the last word!
acmunro
Reynoldsville,PA
Usually it is a mechanical issue not an electrical one. If you unplug the wiring and pop the cover off the wiper motor you will see the pump mechanics. There is a coil in there that activates the pumping action. I have fixed them in the past by using compressed air and blowing the dust and dirt out. Then hitting the key points with some type of lubricant. Maybe silicone spray or WD-40. Something plastic friendly if I remember correctly the cam is made of plastic.
Gripy
Los Angeles, CA
Maybe a new switch. I have the same problem sometimes. I just flick the washer switch back and forth until it decides to stop (usually a few tries).
ARYankee
33
Benton, AR
I also have the same issue but I have a new wiper motor. I guess I'll have to dig a little deeper in the threads and break out the TM to see what I can figure out.
acmunro
Reynoldsville,PA
If you disconnect the red and white wire from the pump (this is the pump action coil) and it still pumps when the wiper motor is on you prob have a problem in the new wiper motor (washer pump arm not disengaging).
ARYankee
33
Benton, AR
I'll check that out and report back. Thanks.
ARYankee
33
Benton, AR
I disconnected them and it still kept squirting so it looks like it isn't disengaging so I'll take the motor apart to see about repairing it.
