cummins fleetguard filter spec?
martinsaunders06
gloucestershire,uk
?please can anyone give me the full spec/info details on a fleetguard LF3479 spin on oil filter, in particular GPM flow rate, ?antidrain back valve?,micro rating and is it full flow, burst pressure etc. have searched google and limited info found. thankyou martin
Albin
TN
Here's the Wix/Napa equivalent:
Part Number: 51458 UPC Number: 765809514584 Principal Application: Case, Oliver and White Farm Tractors, Drott, Hercules, Hobart, Michigan Equipment
All Applications Style: Spin-On Lube Filter Service: Lube Type: Full Flow Media: Paper Height: 8.078 Outer Diameter Top: 4.285 Outer Diameter Bottom: Closed Thread Size: 7/8-16 By-Pass Valve Setting-PSI: 13-19 Anti-Drain Back Valve: Yes Burst Pressure-PSI: 450 Max Flow Rate: 11-13 GPM Nominal Micron Rating: 21
Gasket Diameters Number O.D. I.D. Thk. Attached 2.834 2.462 0.200
From the fleetguard site:
Physical Dimensions Largest OD 107.7 mm (4.24 in) BPV Setting 135 kPa (19.58 PSI) Overall Height 180.09 mm (7.09 in) Thread Size 7/8-16 UN-2B ADBV Yes
