Curious about best apparatus to put in 3.07 middle gears
Reworked LMTV
Expedition Campers Limited, LLC
1,174
TN
Hi Guys,
Well the axles went in for balancing yesterday. Tiger Tool helped a lot. If you use one you must take the zerks out first. They get destroyed.
I need to drop in the 3.07 gears. Just curious about using a gantry and chain hoist vs. engine hoist vs?
I am putting in a locker at the time. Count the number of turns and mark the star nut position? This is what I have seen.
Suprman
696
Stratford/Connecticut
The guy that sold me the locker said to scribe mark everything before taking apart to install the locker and then put it all back together using the marks. I didn’t personally do it I had a local driveline shop do it but it came out fine that way.
Awesomeness
1,518
Orlando, FL
Did you stabilize that massive chunk with anything?
Nope. It sat in the saddle/dish on top of the jack. One person kept a hold of the gears, and one slid the jack.
It would probably work better with a transmission saddle on the jack, but it never felt overly-precarious. (And I'm not the type of person to do blatantly stupid things that are unsafe. If I had felt it was going to end poorly, I would have just gone and bought the transmission jack.)
Reworked LMTV
1,174
TN
I am assuming you did a 4x4, not the 6x6. The 6x6 chunk in the middle is massive.
ramdough
1,729
Austin, Texas
I unloaded an intermediate differential from an F250 once. With three people, it was more of a controlled fall.
For my install, I plan to have the bed off and then do a chain fall from above. Maybe use a motorcycle jack from below.
