Current draw M1009 dead short ??
UncleSam
Anniston Alabama
What is the acceptable (if any) current draw on a M1009?
I've checked my and I'm getting as 5.1 mA reading.
Alternator # 2 has been rebuilt and Alt#1 has been replaced with a know good alternator.
I wasn't sure if the GP Module or some other module in the M1009 would cause that draw or not..
1,176
I would disconnect the battery wire on the rear of each alt, one at a time, and see it that draw disappears. Do not short to ground!
Also, the capacitor/suppressor between the buss bars(passenger side firewall) could be bad. (It's unneeded).
That load sounds too small to be the under dash light(you know you have an interior light, right?)
UncleSam
Anniston Alabama
I'll check these things thanks...yes I know I have a interior light but it only lights up with the turn of my headlight and dash lights dimmer switch, it doesn't come on with opening the doors..
It doesn't draw enough to cause dead battery...yet[thumbzup]
UncleSam
Anniston Alabama
I removed the battery wires from each alternator, with no change to the draw.
Then I tried removing each fuse, one at a time, from the fuse box still no change, I still have a 5.1 draw,
I'll try the capacitor/suppressor between the buss bars, and see if that helps.
Any other places I could check? :confused: :confused:
1,176
You can pull the 12v feed wire off the stud above the GP relay and eliminate all the 12v circuits.
M1008driver
Great Falls, Montana
Just an idea from one of my recent experiences. I would suspect this thing if you have one. Mine had a short on my M1008.
I know you have a different vehicle, but it had a electrical draw. You can disconnect the +- cables at the junction bar to see if that is the source.
TM9-2320-289-34P
FIGURE 46. RADIO FEED HARNESS (M1009).
UncleSam
Anniston Alabama
Thanks I'll check that out also. Great Fall, MT? That a city that I'd love to move to. Any jobs there, in the optical field? I've been making glasses now for over 40 years..
TM9-2320-289-34P
topgun217
The Northern Border of Ohio
Doghead, I'm a bit flustered. "the capacitor/suppressor " could you post a pic? For some reason my front batt. is drawing as well and this is the 2nd. batt. I've put in. Never had a problem until yesterday after the 2'nd batt. replacement.
I've got yet another batt. comming Tuesday. But for now the starter is engaging but not enough to turn the motor over. I checked the grounds and fuses. I hope this is just a bad batt. and not the starter. Currently the batt. is on charger. Somewhere there is a small draw but darned if I can find it.
1,176
Item # 5, circled in red.
UncleSam
Anniston Alabama
I disconnected and checked the the capacitor/suppressor and no change,
I also disconnected the radio feed harness and still no change, still have a 5.8 mA draw.
I disconnected the starter wire and all other hot wires one at a time from the buss bar and still no change in the meter.
Could the battery be bad and drawing on itself?aua
M1008driver
Montana Employment Opportunties - mt.gov - Montana's Official State Website
This place is not affected as much as other parts of the country by the housing crash. You might find a job. I know nothing about your field or work.
I hope you find what is killing your batteries soon. Got to be frustrating. Maybe pull a fuse one at a time and do a check.
EDIT-
Duh, I am so dumb sometimes. I should read more carefully. You might try posting a few pics of your batteries and other things connected under your hood. Maybe it is something simple like a cable or wire that is in the wrong place. Just an idea. I hope you find it soon.
