SteveKuhn
- 4
- 0
- Hasbrouck Heights NJ
I've read most of the dust boot threads but I can't quite find a definitive answer to this question:
Am I pushing my luck running a couple hundred miles with splits in the front boots?
I'm scheduled for a parade on Sunday and have another event coming up in a couple of weeks. Total will be around 150 - 200 miles at 35 - 40 mph. All driving is on pavement - no dust, mud or water.
Both boots have the typical splits reported and had a glop of grease come out and land on the tire when they did. No way I can get them replaced by Sunday and doubtful before the 2nd event. If I could, it'd be done.
I don't want to incur expense through damage to the front axle/brass bushings/thrust washers or a lockup of the front resulting in a hook tow from lack of lube.
A couple of friends say not to worry and more or less go along with the quote I've seen: "Boots are there to keep out dust and water, not to keep grease in." Theory is enough grease remains for required lubrication.
Another friend (and I) worry about those components heating up, freezing, or scoring.
Is there a way to tell if there's a safe amount of grease in there without taking off the boots? What is it?
Got an opinion? I know that there's no crystal ball. Thanks for the sanity check . . .
Steve
Steve
