Dana 44 axles needed
Stayfrostynhm1009
Alton, NH
So being new to this, bought my first M1009 a few months back. Just determined both axels are shot. The previous owner(s) left them high and dry. Was driving it the other day and dropped the drive shafts, fun times. We took them apart today as we were giving them a thorough once over before much needed new suspension install and low and behold they were bone dry and gears eaten up. Any advice or referrals on where to get new Dana 44 axels? Appears hillbilly wizard is sold out. Thanks in advance.
faststandard
50
Birch Run/MI
Unless someone changed your axles, the M1009 front and rear axles were supplied by GM out of their gear and axle plant in Detroit. They should both be 8.5" axles that are referred to as corporate axles. The gear ratio should be 3.08.
Your gear oil has a lot of moisture/water in it. By the way, the differential in the rear axle is an Eaton locker while the front axle has an open differential. Being as though your photo shows the manufacturing holes inside of the cover indicates that this is indeed a GM corporate 8.6" rear axle with an Eaton locker. The tooth count should be stamped into the O.D. in the ring gear - you will have to wipe it off to find them.
4,817
The CUCVs use corporate 10 bolts front and rear on the M1009. Honestly though, and 73-87 chevy 1/2 ton axles will work. You could also probably find a 3.42 geared set. Or maybe 3.73. You could run 33's then. The gov-lock has never impressed me. I've turned 3 of them into kibbles and bits over the years.
cucvrus
10,432
Jonestown Pennsylvania
I have new front and rear M1009 axles in crates. New from GM. Not looking to give them away but they are for sale. pick up or Delivery is an option.
Rex1977
Florida
Hey I am new here, just started working on my old m1009. This may not be the right place for this question I just saw the thread was active. The tires are shot so need new rubbers. If I up size a bit and put 32x11.50R15 would that fit without any rubbing issues or gearing problems?
cucvmule
collector of stuff
1,155
591
Crystal City Mo
Welcome Rex1977
What is customary is to go ahead and start a new thread as to try and keep different problems and solutions separate. Although sometimes they can be intertwined.:burn:
Also a search can be done and you can gather multiple answers and differing opinions. Good Luck
