Deuce fuel tank dimensions...
houdel
9
36
Chase, MI
For what it is worth, capacity is 40 gallons to the "full" mark on the tank, 50 gallons filled to the brim. WARNING - the fuel pump does NOT extend to the bottom of the tank, there is approximately 10 gallons of "unuseable" fuel in the bottom of the tank. I can only assume this was done deliberately to allow water and crud to accumulate in the bottom of the tank to keep the engine running under tactical refueling conditions. Be advised, depending on how your pump and fuel level sender are set up, you WILL RUN OUT OF FUEL when your fuel guage reads somewheres between 1/8th and 1/4 fuel remaining! Ask me how I know!
rmgill
14
Decatur, Ga
You'll run out of fuel on a hill before you run out of fuel on the flats. I've done this. Pulled up to the level spot and at a light right as the engine died. Then scrambled to get the fuel system bled while blocking traffic at a light.
army70deuce
Anderson, SC
Thanks for posting the tank dimentions, I'm planning on putting the tank in the bed inside a job site box and this helps in planning being that I'm half a world away from my deuce right now.
Seth_O
Sac CA
Reviving an old thread (handy search function!) Anyone know the dry weight of the tank? Trying to figure shipping costs :-(.
Wolfgang the Gray
64
New River, AZ
So the "50" gallon tank is really a 30 gallon tank since you can't use the bottom 10 or add in the top 10? What a strange way to design a tank. aua
cattlerepairman
3,276
NORTH (Canada)
The fuel pump attachment is adjustable - you can lower the pump and it will pick up from a lower level, having more useable fuel. Under normal, civy conditions, without fuelling up from cruddy jerrycans etc., that is probably perfectly fine, especially when you make sure that the bottom of the tank is clean.
rustystud
2,815
Woodinville, Washington
After I cleaned up both my tanks ( the main and aux) . I set the pump level to right above the tank bottom with about 1/2" of clearance. It has worked great ever since. I also fill my tanks to the brim when I'm going on a little trip. So basically I have about 48 usable gallons per tank. I only had a problem once when I forgot to turn back on the main switch when the fuel was being drawn from the left tank. I had shut-off the switch because I was tired of hearing the air alarm. Since my system needs power to reroute the return fuel, when I shut-off the power it sent the fuel back to the right tank instead of the left one. Needless to say the right tank over filled and spilled out all over the place ! Going out the breather lines and past the cap. Now when I have the tanks filled to the brim I never shut-off the power switch !
frank8003
4,984
Ft. Lauderdale, Florida
Assure you know the state laws about external fuel tanks before you build it. Some states have heavy duty fines for fuel that did not come from a commercial pump.
