Deuce shift pattern
Jimmy
Louisville, TN
I am not trying to be too stupid but I was looking at the different ignition locks and noticed the shift pattern on the data plate. I have never seen one like that before, what transmission uses this pattern?
JDToumanian
14
Phelan, CA
Most "big truck" transmissions with overdrive have that type of shift pattern, it's just how they're set up internally. A trucker friend of mine said it makes it easy to tell if the transmission has OD or not... OD is always in the upper right, direct drive is always in the lower right...
Jon
acetomatoco
Remember that half a million CCKW and DUKW had an overdrive Clark tranny with the same pattern...only 65 years ago.. RAM
acetomatoco
That interlock is kinda cute, but a master switch on the floor under the co driver seat is my cup of tea..out of sight ....and also prevents folks from leaving the lights on...even to the BL postition cuz then the batts go dead from the dash lights being left on ....etc... RAM
bigmike
355
Dixon CA.
Yep...i'm for adding the master floor switch as well.
