buck1013
- 0
- 0
- coldwater, ms
Is there a starter relay on the deuce, and where is it?
You do not need the starter relay. The Army starter tossing or by-passing these things long ago. They are not needed and its just another thing to break. About 90 percent of my trucks (about 20 trucks over a course of 8 years.) from GL didn't have one or they were by passed entirely.
Correct, you don't run 35-40 amps through the start switch. According to the spec, the solenoid relay (on the starter motor) can run up to 75 amps and still be within design limits.
I have to disagree. I think it was more a lack of maintenance at the end of the deuce life span with the military. The relay was there for a purpose, it worked and could be bypassed either by necessity or sloth in maintenance.
I had a relay make me crazy until I figured out what was wrong with it and replaced it.
buck13 should replace his missing relay for dependable service.
