Deuce Valve Cover gasket TM? Torque spec?
peashooter
205
Hanover, minnesota
I'm a little new to the deuce world and am having trouble finding the TM for replacing the valve cover gaskets on my M109a3 LDT465. I know this is probably super easy but for once I decided I had better read the directions so I dont take anything for granted. Basically wondering if there is any torque spec for the valve cover bolts. I've tried the searches but no luck yet. Thanks for any help
kennys@wi.rr.com
23
Waukesha, WI
Is the valve cover reusable or does it have to be replaced each time? I am looking to reset the valves on mine and I need to know if I have to replace it.
peashooter
205
Hanover, minnesota
its reusable, but they are also cheap so it never hurts to replace them while your at it-I think I paid $12 for a set from Erics. they are thick buggers, probably a good 1/4". I didnt see anything in the TM about using sealant but I did put some on the valve cover just to help hold the gasket in place when putting it all back on.
rccollin
Carlsbad, New Mexico
Im needing to get valve cover gaskets. You aid they are $12 per set from Eric's. Do you have the link to where I can order them from? Thanks.
peashooter
205
Hanover, minnesota
Well, they appear not to be in stock. Here is the link though that has the various part numbers for the valve cover gaskets. Try calling a few of the dealers and or checking their website to see if they have any. Eriks, Boyce Equipment, White Owl, ebay, Saturn Surplus, Eastern Surplus, realcustomtrucks.com (run by a member of this site)
part numbers:p/N 10899080, 375134D. NSN 5330008855723
Erik's link: http://www.eriksmilitarysurplus.com/vacogasetfor.html
