Deutsch or Weatherpak connectors for my DIY harnesses
ramdough
1,729
Austin, Texas
All,
I am making some DIY harnesses for things like lights, diesel heater, etc….
I would like to connectorize it some.
Does anyone have a connector series they prefer?
Some need to be water tight…. Some will not.
Do you prefer a different brand all together?
Skyhawk13205
268
Alaska
I like the deutch connectors. The barrel crimps are superior in my option to the weather pack fold over tabs. The barrel 4 crimp is what is commonly used in aviation circular cannon plugs. The style crimp tool I use is the AF8 with the universal positioner.
Wingnut13
562
Strafford, NH
I’ve used both, yes the weather pack connectors are bulky but I’ve never had a problem with them. That are also inexpensive. As long as they are crimped correctly I don’t think you should have a problem.
As pointed out above the deutsch connectors are more compact. Certainly a factor when thinking of pulling them through a rubber boot into the cab or some such place.
ramdough
1,729
Austin, Texas
I have an AF8, What positioner do you have or recommend?
Skyhawk13205
268
Alaska
i use the UH2-5. It has a set screw to position the contacts, it is very nice when you are working with a bunch of different pin sizes, the problem is it is easy to not position them right and get a badcrimp.
