Did I find some kind of glitch
broknindarkagain
Phoenix, Arizona
I was trolling through old posts in the CUCV section and found posts that are dated from the 1960s and 1970s. When I click on those posts it is pretty much just a blank page with no post on it. See attached image. Not really hurting much, but a sign that something funky might be going on with the databases.
Alexsha
Cache Valley, UT
1970-01-01 00:00:00 UTC is the minimum value of a timestamp field in mysql. It pretty much means there is no value stored there. Not a bug/glitch, just a case not fully handed by the board code.
1,174
The server partied hard in the sixties and seventies and no longer remembers back then.
4,734
That's part of it. The other part is the number of various platforms the board has been on. Sometimes the data moved over gets lumped into null values in the case you've found. And like Alexsha mentioned, the min value for sql is that.
