dogfishtroop
- 2
- 3
- Pataskala, OH
What is best fuel additive to prevent slimming and discoloration of diesel fuel? I have a half tank of 2 month old fuel that has turned green from clear and has clogged my M35a3 pump and filter.
that usually means you have algae in your tank and it needs to be completely cleaned .What is best fuel additive to prevent slimming and discoloration of diesel fuel? I have a half tank of 2 month old fuel that has turned green from clear and has clogged my M35a3 pump and filter.
My 35a3 has the Cat 316 diesel and only drive around a little each month since no shows or parades so have burned about 10 gallons in last two months. Fuel was clear when purchased.How much fuel does She burn in a month, what flavor engine is it, and search within SS is your friend.
Regular old pump 'new flavor" diesel needs something added as that is for new vehicles, not 50 year old engines.
She needs to run, loaded up. That is good for Her.My 35a3 has the Cat 316 diesel and only drive around a little each month since no shows or parades so have burned about 10 gallons in last two months. Fuel was clear when purchased.
