The past few times ive ran my truck it seems the oil pressure is lower than normal. I have jatonkas spin on filters and now i get oil pressure as slow as i did with the old canister style. Also when you rev it up some and let off, the oil pressure goes down to 15 psi or so then back up to 20-25 or so. It used to not do this dropping then coming back up. So today i installed 2 new WIX 51458 filters thinking the others may be dirty. These didn't change anything.
My next thought is maybe the oil is a little low. Could this cause the variation in oil pressure at idle? The first thing i did was check the oil level. Up to the "c" on check when cold, correct? But it looks like in the past my oil dipstick was broken then brazed back togather. So I am thinking the length of the dipstick itself could be wrong. Could someone if they have time measure their dipstick from the tip to the point where it threads into the tube? This would be greatly appreciated!!!
