magpie
- 0
- 0
- Decatur, Alabama
INTRO: Ok, so I'm new to the MEP (generator) line of product offerings. I was able to procure a low time (114.6 hr) MEP-016B with ASK (701a) housing. For a low cost of $(can't post here message for going rate). Finding my MEP-016B in good working order as defined by various observations. None of which made a stick of difference in determining the ultimate "working ready state" of the machine. For example: Some say to NOT purchase one which has rusted screws on the HOBBS (hour) meter. Atypical, I find mine to be rusted but all other gauges and stampings to be complete and intact. With this I leave you the forum scavenger my 2 cents worth of advice, which is equal to all other advice. As it pertains to scoping a machine from GL that you can't start and verify is in good working order. Rather one must rely on visual cues alone as to the last state of the machine. My advice is to look for worn or chipped paint that maybe indicative of a component problem. Examine and know all you can about the component and determine what the repair cost of said such might be. Base your decision on this and what your overall "feeling" of the machine as a whole. With all that said, I came out to the good strictly by chance as I performed NO vetting of the device other than looking at it in person. I am fortunate!
CURRENT STATUS: After procurement, pickup and delivery. I find my unit to be decommissioned per (1-5. LEVELS OF MAINTENANCE ACCOMPLISHMENT). Thus NO filters, batteries removed and NO fuel. To me this is important as the unit was slated for long term storage or GL status and properly obtained decommissioning status. Upon much research on steelsoldiers.com and with the help of ETN550 for fuel filter part #'s, I'm taking the liberty to compile my findings thus far (more detail can be found by perusing the forums, NOTICE: steelsoldiers.com search is rather lack luster and vague. It's NOT Google and will return many items which does not pertain to your intended search. You can ONLY discover what you desire by reading or scanning the threads which the search hit's on. NOTICE: steelsoldiers.com will NOT return ALL relevant material or hits through Google or any other search engine. Steel Solider website requires an account be created prior to displaying ALL search hits relevant to ANYTHING you may search for. BTW, they are a great community why would you NOT join? It's FREE!):
Fuel Filter: NAPA 3516
Air Filter: Baldwin PA5579 (UNTRIED as of the writing of this article. Item is special order from NAPA and am awaiting receipt. DO NOT hold me accountable if it does not work. Will update thread when I KNOW it is correct)
Oil Filter: Purolator L24484 (Others may work and be of better use)
Oil: Straight 30W Heavy Duty (read this somewhere on steelsoldiers.com others viscosity's may suffice)
Nonetheless, I proceed with attempting to start the engine. And much to my chagrin, the engine fires for the first time since 1988 as far as I know. Only to sputter out when the old lingering JP4 abolishes itself from the bowels of my Onan Q106D-I/10399A. So I am now left with the prosperity of having a complete working engine (electrical thread soon to follow, when I get there). I then read the manual and heed the CAUTION as listed above. So I proceed to drain the fuel filter reservoir of all fuel. And continue to manually prime while noticing the priming lever is sticking upon release (after depressing fully this time).
So my question is this: Have I damaged my fuel injection pump (if that is the actually name of the fuel pump itself). Or do I need to continue with my priming until I can obtain a fuel flow from the secondary fuel line leading to the injector? I did manage get a few bubbles to the injector (once loosened). What's the prognosis Dr.?
MY PROBLEM: In attempt to initially start my unit. I drained all the remaining JP4 from the fuel filter reservoir and cleaned the SUMP from the fuel tank (as it was clean other than some moisture accumulation). Upon installing oil filer and oil, I lastly installed the fuel filter (that's right last; if you read the full article you would understand that I am awaiting the back order of the air filter). Upon priming system for 15 min I realized that I should add some fuel to the fuel filter reservoir to assist in the priming.
-----------------C--------A--------U---------T--------I--------O---------N-----------
Do not attempt to prime fuel system
fuel filter assembly. Doing so can
fuel injection pump.
Disregarding what I had read in the days leading up to my obtaining the appropriate filtration, as I'm an eager cuss. I added fuel to the reservoir and continued to prime my hear away. Listening for the tale-tale sign of fuel trickling back into the fuel tank as an indication of success (achieved). Only then did I realize I wasn't FULLY pressing the priming lever and felt NO resistance. DUMBITIS strictenes(sp?) me to no avail. I realize that I have screwed the pooch, committed the unthinkable, sold the farm to the devil or even bought it from my "eager cuss'. -----------------C--------A--------U---------T--------I--------O---------N-----------
