Does a GOVT rebuilt Multifuel in Crate need a Long Run in Procedure?
Greensick
Mastic Beach/NY
Hi all,
So this morning I get to thinking. When the GOVT rebuilt and preserved the Multifuel (mine in '92) and sent off in crate, has that engine been "run in" already to check all the necessary boxes that is is a "good" Engine? Would it be sent out into the field and then have to go through this LONG run in procedure only to find out that it isn't up to par. Or is it already "broke in"? . It would seem to make more sense in theory, that you could open up and drop in the "needing" vehicle and be battle ready. Thoughts?
TYIA
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
Heavy engine break in procedure is immediately after warmup check for leaks and put a heavy load on the truck and drive.
They stand ran it. They might have dyno ran it but they didn't load it like a heavy truck and trailer can.
V8srfun
538
Altoona pa
I personally do not believe in running a engine in regardless of what fuel it runs on. I get a heat cycle or two on a fresh engine (just enough to get all the fluids checked and adjusted) then run it like you stole it. If a engine is going to fail I want to know right away not after I babied it around for months and waisted a ton of money on 10 extra oil changes.
