Does anyone have tow bar dimensions?
harleyrkc
Burton, MI
I tried the search function and didn't have any luck. I'm going to look at a pair of tow bars here locally. But I don't know what the dimensions of the original deuce tow bars were. Length, width, pin hole sizes on bar and adaptors? I was already told there a little over 4' long and slightly over 100 lbs. each.
1,808
The medium towbar with single adapters and all the pins will come in just under the 140# mark. If you attach both adapters to the swing arms and nothing to the lunette arm each piece will come in just under 70#, the magic number the brown truck drivers charge excess to exceed.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
At the lunette end there is a one inch pin. The legs are adjustable in length, those pins are 3/4 inch. The ends where the "feet" attach is one inch again.
