Dome light install in a hardtop
number9
Lexington, KY
I have searched many times but never found an easy clean install of the armor dome light in a hardtop truck. Thought I'd post up the route I went in case others wanted to get some ideas.
I picked up a joint of flat stock steel at Lowes to make brackets out of. Cut them to length and drilled mounting holes, then shot them with some walmart camo flat black.
I drilled holes in the headliner support strip to bolt the brackets to. Used 1" long nylon spacers from the parts drawers at Lowes to space the light down to clear the headliner support. I ran power along the channel where the hardtop meets the cab above the windows, around behind the passenger door and down the back of the cab, through the hole in the floor for the slave cable and down to the battery + terminal. I couldn't seem to find any other easy tap for power. I ran ground also along the hardtop channel to the 1/2" bolt that secures the hardtop to the windshield frame above the steering wheel.
I decided that the light would work out better turned sideways - this would allow the light to evenly and directly light the floorboard at night without my body casting any shadows and also located the light switch in a position that turned out to be very ergonomically friendly as when I reach up for the light my thumb falls right on the push button to flip the light on.
The light is MUCH brighter than it looks in the pic.
***ETA*** - I just realized I forgot to install an inline fuse. Guess I'll have to go back and do that. :doh:
Bill W
45
Brooks,Ga
I welded my dome light brackets to the hardtop using some angle and 4 coupling nuts, I mounted mine in the rear of the cab., excuse the ugliness as was in the middle of sanding/painting
1,808
You will wonder how you ever got by without the light. I put them in all my trucks. The front location does have many advantages.
Bill W
45
Brooks,Ga
I would have mounted mine up front but I installed a spotlight there instead
Bjorn
Thats one nice setup you have there.
JCKnife
46
Kentucky
That's a nice-looking install. Can you tell me where you got the wiring connector? I'm about to do the same thing.
JCKnife
46
Kentucky
I ordered the connectors from Eriks Surplus. He sells them in a set of both male & female type.
You don't have a part#, do you?
I found their "rubber shell connectors" but there are five different varieties...
JCKnife
46
Kentucky
Jimma
Hartwell, GA
Call Erick's and see what he can do on the shipping?. I ordered my wire conectors and a few things including a 24v tag light and he put them in a $5 priority mail package and got it from the west coast to Georgia in two days. I was happy with the product, shiping and price.
JCKnife
46
Kentucky
OK, Napa part # 784353 Female Snap Terminal-Nylon. Plugs right into the light--snaps in quite firmly in fact. A box of 10 pcs cost me $3 and change.
I also bought plenty of 14 ga wire so I'm all set.
JCKnife
46
Kentucky
Got the first light in the cab. Tried drilling a hole in the soft top support bar to snake the wires through that but couldn't stuff them through. Oh well.
Hey, here's a tip I haven't seen posted before: I wanted to remove the stop-post that prevented easy turn-on of the unfiltered light (I'm not exactly worried about light security just now). I found that if you remove the switch (1 screw) and flip it over, the stop post is actually threaded. When you unscrew it, the pushbutton and spring come out as well. So I could put them back in if I want to. Neat trick.
Anyways, thanks as always.
Joe
Billy Bobbed
13
Terre Haute,Indiana
Joe[/QUOTE]
Im going to get one,thanks for the tip.Just havent decided were to put it yet.Theirs been alot of times I needed a dome light.
