Dragging brakes on M35A2
DirTDel
Royal City, WA
I’ve got a couple of M35’s that I use in my water well contracting business. One has an air compressor on it. The one I’m having the brake problem with has a cable tool drill rig mounted on it.
It was surplused from my fire Dept and I bought it thru the GSA auctions about 4-5 years ago. Used it occasionally with a 1,000 gallon water tank in it. Last summer I pulled the military bed off it and mounted the drill rig. Took it out on a job 30 miles away and back again no problems.
in December, I took it out on another job and the brakes started dragging. They weren’t fully releasing after application. Brought it back to the shop yesterday. Same problem. If I stop completely, shut the engine off and apply & release the brakes multiple times, they seem to release again. But if I apply them, while slowing for a turn, they would not release unless I completely stop and apply and release them with the engine off.
im assuming it’s the master cylinder and/or air pack. Any advice?
sandcobra164
288
Leesburg, GA
How much free play do you have in the brake pedal? With the truck running or just air pressure built up, remove the master cylinder cap and apply and release the brakes. You should be able to see fluid drop slightly when applying and rising upon releasing. What I found on a friends truck is he adjusted the free play too "tight" on the linkage to the master cylinder and it would do the same thing after a few stops. Another issue could be a broken or missing return spring on the linkage. It the master cylinder does not return to "release completely" for whatever reason, the air pack and the rest of the system will stay applied to some degree.
DirTDel
Royal City, WA
I’ve has this truck 4-5 years. Never had to do any work on it. As I remember the brake pedal used to go about half way to the floor to apply the brakes. Now I have maybe an inch or two pedal travel.
1,176
Take the plug out of the back of the booster and see if there is air pressure(with your finger over it) with it running.
If there is, you need to repair your booster.
You know, the plug you lubricate it through, for maintenance.
rustystud
2,815
Woodinville, Washington
Just to clarify for you, he means the engine running with "NO" brake applied. There should be no air at this time. If there is air present then the "air control valve" is not working correctly. Could be gummed up.
DirTDel
Royal City, WA
Thanks guys. I searched but didn’t find the thread mentioned. I got the tech manuals with the truck, but don’t really help with troubleshooting.
TMNT
Canton, Ga
Mine has been sitting for more than a year now, for the same issue. I maintain my truck pretty well but I had no idea that the air pack required periodic lubrication. The good news is that I’m motivated to get out there and fix it as soon as the weather improves a bit. Thanks.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
With this issue, lube will not help for long. Its time to rebuild/replace.
rustystud
2,815
Did you pull the plug like Doghead mentioned ? It is a square head pipe plug in the very back of the "air-pack" (booster) .
2201.jpg The plug is on the left side.
Big Tom
114
Millington md
Just some problems I've seen , pull the rubber boot back on the master cylinder, u should see the piston all the way back against the snap ring if not your pushrod is to long or Rust on dirt is keeping it from comming back. Witch will block return hole. Also like some said take top off fluid should move down and back up the return hole could be clogged up not letting fluid back , which will keep brakes applied . If either is Wong get rebuild kit not a hard job .
Big Tom
