Bisdale
- 0
- 1
- Sacramento/California
I just drained and refilled my spicer on my m35a2 multifuel. I also took off the top of the transmisson to inspect the gears. I've sealed it up and it dry shifts through the gears fine. To be safe, I started the truck with the clutch depressed, but when I try to let the clutch out with the spicer in neutral the truck begins to stall out! The truck isnt trying to move, I do however have the parking break on. I dont want to take it off just yet as I have one of the front wheels off and am rebuilding the hub and seals. I am confused and concerned.
When I was in the gear box, I detached the output drive shaft and pressed the clutch down in order to be able to rotate the gears to inspect them. Have I somehow messed something up? Or am I just dumb? I made sure my forks went back into there slots when I put the top on the spicer. And as I said, it dry shifts into all the gears fine.
