Driveshaft question
Joeinderry
Derry/NH
I am going to have my drive shaft extended. My question is: Can I use the back driveshaft (the small one)? Is it the same as the front driveshaft just shorter? If I can have the back one extended I can keep my other original if I need to use it on another truck. How about cost to extend it? I see here on SS some people said they payed $100-200. I made a couple calls to local shops and without seeing the shaft I got quotes of $400-600. Sounds pricey to me. Thank you for any help. Joe
Reckless
Georgia
I got quoted about $600 to make a 97" in long driveshaft with a carrier bearing for my crew cab. So if its for a bobber and extending the shaft 5-10" that's a little pricey!
welldigger
15
Benton LA
It was over $500 for the shaft to be extended on the a3 me and a buddy are bobbing. That was with new u joints installed also I believe. The short shaft between the bogies I believe has the same ends as the long shaft. Tho even if they do have the same ends it won't matter since they will cut the ends off and put a whole new tube in the middle and then rebalance it.
11Echo
92
CT W. R.
Mine have been $125 if they already had a tube length for my need in stock.
$200 if they did not have the correct tube length I needed in stock.
m16ty
218
Dickson,TN
I just had one shortened today on a '94 Pete that I shortened the frame on. Cost me $80. The Pete driveshaft is twice as big as one on a deuce but I do realize it would probably cost more to lengthen one than it would to shorten one but not that much.
Joeinderry
Derry/NH
Thanks for everyones input. I will be bringing it to the shaft shop within the next 2 weeks. I'll repost how long I had it made and the cost.
