Dropside Bed questions
opie65
Huntsville, AL
With the Drop Side Bed, can you run with the Tailgate Down?
How about in the extended (Horizontal) position?
Troop Ladder still work?
Thanks!
cattlerepairman
3,239
NORTH (Canada)
Thanks!
1) I would not...obscures view of stop lights and bangs around.
2) Yes; secured by the chains
3) if you mean whether you can use the troop ladder when the tail gate is in the horizontal position - yes
steelandcanvas
85
Southwestern Idaho
Yes you can run w/ the tailgate down, and horizontal position, although my tailgate does not lay a true horizontal. I don't have a boarding ladder, but I can't imagine why it wouldn't work. Castle Bravo (classifieds) has the dropside brackets, just in case you need them, I bought one from him last wek.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
I agree about NOT running with it in the down position. You can run with it hung from the chains, but you need to make a spacer to fit in the T bolts so that it doesn't bounce them out. They don't tighten up enough on their own to keep it in position.
1,807
It's the noisiest frickin bed known to man. I threaten to dispose of mine any time I drive the truck. I've only dropped the sides one time. Mine has hooks on the tailgate instead of the T-bolts. I do have them in the tool box if needed.
rlwm211
Guilford, NY
My Deuce is a drop side. I find the convenience of the drop sides invaluable.
When I want to have the tailgate horizontal, I found at first that the chains and T bolts are too short to allow that. I use a clevis to extend the T-Bolt to the slot where the T bolt goes and that allows the gate to be level and there is some minor adjustment available with the threaded handle to make sure both chains hold the same tension.
The Clevis I have are from tractor supply and are 1/2" if I am not mistaken. I put the hoop part of the clevis around the T Bolt and the pin through the slot. Generally the handle is in the down position. It is dark at this point, but tomorrow morning I will snap a photo of my setup.
RL
1,807
Now that's the way to go. How do you change from one to the other? Did you use a carabiner type connection?
When I bought it from President Bush it had the hooks. Gimpy gave me the t-bolts. I just use them without the chain when I need them. I think they used a cold shut link on the chains.
