- 228
- 58
- 28
- Chesapeake, VA
My deuce hasn't been on the road in a few years do to torque rod bushings and finances. A few months ago I put some batteries in it to just to start it and drive around yard. I had no brakes. Checked master cylinder and it was dry. I added the correct brake fluid type to master cylinder and over filled it. Obviously master cylinder is now covered with fluid. I looked at all the tires looking for brake fluid and seen none. Check for obvious leaks around brake lines and didn't see anything. This past weekend I drove it around yard and I just barely can feel brakes engaging. Looking for some advice and opinions on where to start. I did replace the wheel cylinders up front years ago. Should I start with a brand new master cylinder for piece of mind and then work my way towards wheel cylinders? What about air pack? I hate to go through the system and just to find out master cylinder is bad. At same time hate to replace that if not needed. Anybody replace master cylinder just because for safety reasons?? Thanks for advice. Just not sure where to start.
