290smallcam
- 36
- 28
- peru,indiana
I've found the size for a DT466E but not for one with the p pump. From flywheel housing to fan hub, how long is it if someone has one out laying around. One site says 42 other 45??
It would sure be tight to make a cooler fit. My thought was, since I wouldn't be cranking up the horsepower, it would probably be just fine without an aftercooler.so with flywheel housing it'll be about 45''. Same as LDT-465. Don't think a ATAAC will fit in front of radiator. Maybe if a electric fan was used that might free up an extra inch or so?
I'm not sure. A flat type pan from a generator application wouldn't be good for road use even if available. Most I've seen have really strange dual sump pans with protrusions in odd places.Do they make a low profile pan?
