EGT gauge
rickdavis81
84
Rich Hill, MO
Had to adjust the fuel on my M51 multifuel today, starts right up and idles great now. I think it might still be a little low but I want to install an EGT and boost gauge before I go any farther. What ones are you guys running? I'd like something that matches the interior and doesn't look to out of place. Are all the lights and dash gauges 24 volts?
porkysplace
1,487
mid- michigan
Plenty of information for you in this link ;https://www.google.com/search?sourc...0i22i30k1j33i22i29i30k1j33i21k1.0.w3AJwi5CSeo
Lukes_deuce
124
Long Island, NY
Everything on the truck is 24V. As for gauges, you have many options. I run old gauges off my dodge cummins. I suggest using gauges that do not require power for the sensor, only for the lighting.
ChrisMc
Houston/Tx
Isn't there a 12v line that runs to the blower switch for the low fan speed? I'd think it would be easy to tap off of that to get power to a 12v gauge.
Sent from my XT1635-02 using Tapatalk
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
Its not a ground side switch on the blower. Its off the dash switch. Same #400 wire delivers 12 and 24.
You could steal it off before the switch though. But hopefully its not enough amps to be an evil wire
Sent from my SM-G935P using Tapatalk
Lukes_deuce
124
Long Island, NY
Those gauges look nice. Clean and simple as well as a good price. Post up pictures of where you install them. I might have to get a trans temp gauge from temp!
