engine fan always engaged ?
seano11
103
Edmonton Canada
The engine fan on my truck is either stuck on or never comes on. when the engine is shut off I can't turn the fan by hand and when the truck is running it never gets above 175-180 any ideas?
LanceRobson
206
Pinnacle, Stokes County, NC
It might just be that the engine isn't working hard enough. The engine will never get very warm at idle unless you cover the radiator. Even running it at 1,000 RPM won't get it hot enough to open the thermostat.
Even with a heavy load mine doesn't get above 190 even pulling a hill on a warm day. I suspect that it has to do with the cooling system being sized for a heavy load on a 125 degree day....
Lance
jaxsof
15
Dundalk, MD
Could be that diesel engines dont run as hot as gas engines, too. You have a truck that was spec'd to carry 10,000 lbs up a 60* incline in mud.
73m819
320
gainesville, ga.
The 809 series DOES NOT have a fan clutch, it's direct drive, 175/180 is about where it will run, my 819 goung down the road at about on tack RUNNING hard never goes over 190.
The -10 REALLY is your FRIEND
EMD567
Driver for the Ga Mafia
47
Aiken SC
Mine runs about 200 on the gauge, but I think the gauge is lying to me. I am gonna purchase a laser temp gauge and check it.
1,177
A quick look at the -34P TM might have answered your question.
F18hornetM
10
Ocean City, Md
Actually a quick look at the fan and you can tell there is no clutch. Pretty straight forward desgin. Fan blade bolted to a hub. 180 is great, mine runs in the same range even on hot day
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
Wow, pretty hard to look under the hood of your own truck and answer your own question.
M813A1
OKC, Oklahoma
Well it depends on which model truck you for the fan to turn constantly !! The M809 Series has a direct drive Fan and the M939 Serires has a Fan clutch that will stay off untill it get to the high temp setting and then kick in and if it turns all the time then you have either have a bad temp sensor or the fan clutch is stuck closed !! Because the fan should not turn until it reaches the high temp setting then it should kick in and draw the air through the radiator for cooling. As well you could have a bad or clogged air line going into the fan hub to operate the fan clutch. Good Luck troubleshooting ??
